Runtime error (IndexOutOfRangeException): index out of range: 0
Traceback:
line 117, in __build_module, "C:\Users\jimbo\AppData\Roaming\McNeel\Rhinoceros\5.0\Plug-ins\IronPython (814d908a-e25c-493d-97e9-ee3861957f49)\settings\lib\ghpythonlib\components.py"
line 126, in , "C:\Users\jimbo\AppData\Roaming\McNeel\Rhinoceros\5.0\Plug-ins\IronPython (814d908a-e25c-493d-97e9-ee3861957f49)\settings\lib\ghpythonlib\components.py"
line 1, in script
Even a script with this single line
import ghpythonlib.components as ghcomp
produces an error. Importing rhinoscriptsyntax works fine. Any hints how to solve this?
sorry nobody checked this thread and answered it earlier. I missed it. It seems it’s still relevant.
This seems to be a problem in the components module – and I am not an expert in that module, so I would need some help tracking it down.
Are you having access to Rhino WIP? The components module was slightly changed, and maybe it will work there. Please perform a test on Rhino WIP.
As I am not seeing the issue, I believe this has to do with a third-party add-on you have installed on your machine, but which I do not.
The only sure way to rule that out, is to move all your third-party libraries, excluding GhPython, on a memory stick, and removing the memory stick. Then, restarting Rhino & GH.
If this fixes it, then they can be added one by one, till the problematic one is found. I suppose components that do timer, looping and similar concepts might cause problems with this library, but I do not know for sure.
I have the latest WIP installed (6.0.16152.9051, 05/31/2016), same problem here. With the method you described I nailed it down to one plugin which seems to cause the error: Vipers http://www.food4rhino.com/project/tangchi?etx (attached as zip).
Can you repeat the error on your machine?
The fix for GHPython component being “compatible” with Vipers component has been released as a part of Rhino WIP Grasshopper?
There was a user today who reported this issue again with Vipers component on Rhino 5 and GHPython 0.6.0.3.
