Python cannot load ghpythonlib.components
Hi all,
Did any one have the same problem and find a solution to this?
My python fails to load the ghpythonlib and showing " lightexception object has no attribute ‘component’ ".
Most of my scripts have use a lot of ghcomps invole and now they all not working… T_T
Thanks for any hint,
Jack
Hi @Jack_Zeng
were you able to fix this? Was this in Rhino WIP or Rhino 5?
If it is in Rhino WIP, this should have been fixed in the WIP released just one day after you reported this.
Thanks,
Giulio
Giulio Piacentino
for Robert McNeel & Associates
giulio@mcneel.com
Hi Piac,
Thanks for your reply. I am using Rhino 5.
The problem on Rhino Python goes away after I have run the Ghpythonlib in grasshopper.
I found that Steve Baer has told that we need to run the Ghpythonlib in grasshopper at lease once before we use it in Rhino Python.
Thanks,
Jack
Thanks. I reported RH-36453 so we can address this.
RH-36453 is fixed in the latest WIP
