I am using the last Version of th Rhino WIP for Mac (5E12W).
I am experiencing some difficulties to import the ghpythonlib.components as ghcomp
Every time I get an error: Runtime error (MissingMemberException): ‘LightException’ object has no attribute ‘components’
I have searched for any solution but didn’t find anything that have worked.
I have tried to reinstall the Rhino and also was trying to install the Python Component, but nothing have worked.
I hope that someone could help,
Best wishes,
Iurii
ghpythonlib was developed as a Rhino for Windows feature. It hasn’t been tested and manually ported to the Mac, yet. Codebase is similar and right now it is probably a port of the Windows version, so there are chances it will work. Once it will, I’ll make sure you know.
Giulio
Giulio Piacentino
for Robert McNeel & Associates giulio@mcneel.com
I have the same error, but I am working on Windows. Solution exception:‘LightException’ object has no attribute ‘components’
Do you have any idea how to solve it ?
ghpythonlib should now be working (mostly) in the latest RhinoWIP. We know there’s an issue (that we’re currently working on) with Node In Code calls, but we’ll get that worked out. Please give it a try.
