GH Import Content component and VA Elements and Parameters
I need to compare two IFC files (geometry and parameter values). I created two Rhino files with IFC imports in each file. Well, this method is not working, at the bottom of the screenshot you can see that I can’t convert Model Objects imported this way to the Block Instances (VA component) which is a necessary step to obtain Property Names. To overcome this issue, I must import both IFC files into the same Rhino file, which is far from being an optimal approach.
More about inconveniences with reading data from Block Instances / Meshes / Breps…
@czaja, I can see the Property Names component doesn’t work with geometry imported from other files. We will revise this issue.
