I have been getting the following error message in the Rhino Python editor recently. This has not happened before (as in this error only started cropping up when I tried to run the program today), and now I cannot identify what is causing the following error message.
Message: unexpected token ';'
The editor says that the the line below is causing the error. I have already tried restarting Rhino, but the error persists.
# Sortal Library Imports
# Error happens in the this line of code
from sortal import (transformSet, rule, primitiveSort, point3D, point2D, coordinate, lineSegment3D, planeSegment2D, lineSegment2D, line3D, label, weight, disjunctiveSort, attributeSort, affineTransform, vector3D, vector2D, planeSegment3D)
# User-defined sort type imports from sort_types
from sort_types import sort_types
# Import for transformations
from mpmath import pi, sin, cos
In the editor, it looks like this. The error happens at line 24.
Is an indent or a white space possibly causing this error?
