Hi guys,
Do you know how can I get the block instance current Rotation ?.
Is it possible through the block instance Xform?. I have tried to use the blockinstanceXForm and it returned to me a Transformation Matrix 4X4.How can I use that to get the current Rotation relative to the initial Rotation ?
Any Ideas pleas ?
This is how the Matrix Looks like:
R0=(0.984807753012208,0.17364817766693,0,31.5810718028205), R1=(-0.17364817766693,0.984807753012208,0,17.2116287951364), R2=(0,0,1,4), R3=(0,0,0,1)
If there is another easy way to get the Z_Rotation, just let me know pleas !.
cheers,
Ghaith
It looks like there is an Transform.GetEulerZYZ method https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_Transform_GetEulerZYZ.htm
I dont know how to use it though…
-Graham
Hi Graham,
Thank you for your Reply. Do you have a method to generate the Minimum bounding box for a list of objects ?
I have found this one from MinimumBoundingBox.py (17.5 KB) Helvetosaur as well
