Is it possible to get the material of a wall part.
I am able to use the ‘PartGeom’ component to get the part geometries of a wall, but I can not work out how I can get the materials of these parts.
Thankyou
Thankyou
That is fantastic, my only question is-- I am guessing it does not order them in their correct build up order?
Amazing!
When i use the component- when a family has say a line within it (say a symbolic line etc) the component fails because the element is not a brep.
Would it be possible to update the node so it only tries to operate on breps.
Usually it would be fine but when it finds anything but a brep the component does not continue working for any element after the fail-
Rather than just skipping over the fail.
Otherwise fantastic!
Can you provide an example? I wouldn’t expect the Element Parts Geometry component to work in that context.
Of course,
In the image below, you will see the component fails because it tries to operate on a Line (I beleive this is a reference line- refer image 02)
When I delete the reference lines- it works fine.
I would imagine it the node should cycle over all the elements and just ignore anything that is not a brep. The issue is, if it finds a non brep, an error is thrown and the operation stops.
Ssw, The material can be controlled by the object style or a parameter, a general solution isn’t available that covers all possible conditions in the native components.
Revit Geometry Materials.gh (11.5 KB)
Hi @Japhy
I am using the element geometry by sub category node- it usually works fine- until it throws an error when it collects a line rather than a brep- refer to my earlier post.
Please see the definition i posted above, it accounts for the model line error.
Fantastic. sorry I missed that. That extra bit of code works a treat.
