Hello guys,
i’m tackling an issue with applying mapping transform during the evaluation of texture: https://github.com/mcneel/rhino-developer-samples/blob/156a0e8646394ec5e47b28751aeb35427d52cf44/rhinocommon/cs/SampleCsRdk/CustomTexture.cs#L112
This seem to work only if i set in code (in particular in RenderTexture constructor) sth like:
SetProjectionMode(TextureProjectionMode.MappingChannel, ChangeContexts.Ignore); SetMappingChannel(1, ChangeContexts.Ignore); SetRepeat(new Vector3d(4, 4, 4), ChangeContexts.Ignore); SetOffset(new Vector3d(.2, .2, .2), ChangeContexts.Ignore); SetRotation(new Vector3d(1, 5, -5), ChangeContexts.Ignore);
But when i try to manupulate channel by hand in texture mapping panel nothing happens like the tranform would never be updated.
Besides im unable to bring Texture Mapping section it never shows up:
ModifyRenderContentStyles( RenderContentStyles.LocalTextureMapping, RenderContentStyles.TextureSummary);
Also is there any good reason for fact why only TwoColorRenderTexture can have additional UI sections and standard RenderTexture can’t ?
I know Nathan will be offline for a while so @dale would you mind doing a small research on this topic?
