Get2dRectangle() question
I use Get2dRectangle() to get points.
bool b = false;
while( true )
	CRhinoGetPoint gp;
	gp.SetCommandPrompt( _T("Drag a window to select points") );
	gp.SetGetPointCursor( RhinoApp().m_default_cursor );
	gp.ConstrainToTargetPlane();
	gp.AcceptNothing();
	CRhinoGet::result res = gp.Get2dRectangle( 0, 0, FALSE, PS_DOT );
	if( res == CRhinoGet::nothing ) break;
	else if( res == CRhinoGet::cancel ) {
		b = false;
		break;
	else if( res != CRhinoGet::rect2d ) continue;
When program running at gp.Get2dRectangle(), I use “Lasso points” to select points.
In Rhino4 it works, in Rhino5 it does not works.
How can I do?
Best Regard,
Vaker
Can you provide a full working sample of what does not work (that used to work)?
Hi Dale,
Sorry, my mistake.
It is ok now.
Thanks for your help
Best Regard,
Vaker
