I’m calling Get2dRectangle() to get an on-screen rectangle. If the rectangle is drawn with the mouse - everything is OK. However Rhino accepts typing the coordinates on the command line, instead of clicking with the mouse.
For example here I typed some coords for the two corners
and the result has nothing to do with the actual values:
If I call CRhinoGetRectangle::Corners() I actually get the second point correct in this case, and I see that m_preview_point holds the value. However I couldn’t find a way to access the first point’ coordinates
Does anyone has an idea how to get the typed coordinates ?
The typed coordinates are transformed to screen coordinates by doing something similar to this:
var point3d = ...
var view = doc.Views.ActiveView;
if (null != view)
var world_to_screen = view.ActiveViewport.GetTransform(
CoordinateSystem.World,
CoordinateSystem.Screen
var point2d = point3d;
point2d.Transform(world_to_screen);
// TODO
To get a 3d point from a screen point, just create a screen-to-world transformation and transform the point.
that transformation was the first thing I tried, and it didn’t work
here I typed 100,100 and 200,200 as inputs. Assume the rect’s corners are the top-left and bottom-right coordinates of the typed points and here is what I get:
I need to get whatever the user has typed - (100,100), (200,200), but got (-2145, -746), (-2423, -719)
It doesn’t really matter if I get the CRhinoGet’s View() or the document’s ActiveView() the result is the same.
Furthermore, the user may click for both points (then Rectangle2d() returns correct); may type the first point, click for the second point, vice versa, or type both (then Rectangle2d() returns wrong). Assuming there is a transformation that returns the correct numbers, how to know when to apply it and when to take the Rectangle2d() result directly ?
Furthermore 2, if the first coordinate is typed, the dynamic rectangle is not drawn on the screen when moving the mouse for the other corner. Is that a bug ?
I think I’ll try to write my own CRhinoGetPoint inherited class an capture the points somehow
Thanks
I made it work. Quite ugly, but it does exactly what I want.
p0 and p1 are screen coordinates of user points, entered either by typing or mouse clicking
RhinoApp().Print(L"Specify screen rectangle\n");
CArgsRhinoGetPlane args;
MyRhinoGetPoint gi(args);
gi.AcceptNothing();
ON_2iPoint p0, p1;
switch (gi.Get2dPoint())
case CRhinoGet::point:
//Typed coordinates
const ON_3dPoint p = gi.Point();
p0 = ON_2iPoint(p.x, p.y);
break;
case CRhinoGet::point2d:
//Mouse click coordinates
p0 = gi.Point2d();
break;
case CRhinoGet::cancel:
return CRhinoCommand::cancel;
default:
return CRhinoCommand::failure;
//pick the second point only
//enable dynamic drawing of the rectangle frame
POINT screenStart = { p0.x, p1.y };
switch (gi.Get2dRectangle(gi.View(), &screenStart))
//Typed coordinates
p1 = ON_2iPoint(p.x, p.y);
break;
case CRhinoGet::rect2d:
p1 = gi.Point2d();
break;
default:
I’m not sure I understand the question. If you want to save the point, the save it on some structure that will persist after the function returns. Or am I confused?
