Get point at intersection
Hi All,
How I can get point at intersection in my truss below
TRUSS.dwg (264.8 KB)
Thanks
Not very specific question but i guess you should look at:
Line | line
Or
Curve | curve
I using control point but maybe the result is not ok. For example I have four lines but control point get for 8 points
You may want to try MCX BTW, you should get rid of duplicate points.
Or if you don’t mind to use other plugins, then, Heteroptera or sandbox-topology plug-in could be of use…
IntersectionPoints_re.gh (24.1 KB)
Thanks @HS_Kim so much
