is there an easy way with RhinoCommon to get all objects which are on a certain layout page?
Thanks, Jess
Hi Jess,
I’m thinking you need to look in the ObjectAttributes class for each object - there are for example the Space and ViewportId properties which might return a specific ID of a detail viewport to match… dunno, haven’t tried, myself…
–Mitch
Hi Mitch,
great, thanks! I knew about the Space attribute but I was missing the addition with the ViewportID.
This seems to work:
"""Returns identifiers of objects on a PageView by ID
Parameters:
id: guid of the PageView
include_lights (bool, optional): include light objects
Returns:
list(guid, ...): identifiers for objects on PageViewId.
import scriptcontext as sc
import Rhino
def ObjectsByPageView_id(id, include_lights=False, include_references=False):
settings = Rhino.DocObjects.ObjectEnumeratorSettings()
settings.HiddenObjects = True
settings.DeletedObjects = False
settings.IncludeGrips = False
settings.IncludePhantoms = True
settings.IncludeLights = include_lights
settings.ReferenceObjects = include_references
objects = sc.doc.Objects.GetObjectList(settings)
ids = []
for obj in objects:
objRef=sc.doc.Objects.Find(obj.Id)
attr = objRef.Attributes
if attr.ViewportId == id:
ids.append(obj.Id)
if ids:
return ids
if __name__=="__main__":
page_views = sc.doc.Views.GetPageViews()
if page_views:
page_view_ids = []
for page_view in page_views:
page_view_ids.append(str(page_view.ActiveViewportID))
page_view_id = rs.ListBox(page_view_ids,"Select Objects on Layout_ID","Objects by Layout")
if page_view_id:
objs = ObjectsByPageView_id(rs.coerceguid(page_view_id))
print objs
