I’m trying to modify Kelvin Cheng’s script that prints one PDF page of each Layouts as a separate file. I want to add to each PDF file’s name suffix of a text object in that layout (it’s a revision note).
I thought of retrieving that text object’s contents by finding it using Rhino.Display.RhinoPageView object, but I can’t seem to find a way to retrieve objects by view.
import Rhino
import scriptcontext as sc
import System.Drawing
folder = rs.BrowseForFolder()
prefix = "XXXX-XX-XX-XX-XX-X-"
folder += "\\" + prefix
name = "layout_revision"
settings = Rhino.DocObjects.ObjectEnumeratorSettings()
settings.NameFilter = name
def createSinglePDF(view):
pdf = Rhino.FileIO.FilePdf.Create()
dpi = 300
settings = Rhino.Display.ViewCaptureSettings(view, dpi)
settings.OutputColor = Rhino.Display.ViewCaptureSettings.ColorMode.DisplayColor
pdf.AddPage(settings)
filename = folder + view.PageName + '.pdf'
pdf.Write(filename)
for i in sc.doc.Views:
if type(i) is Rhino.Display.RhinoPageView:
createSinglePDF(i)
Thanks, yes I didn’t know that view.ActiveViewportID is where PageView’s Id were stored. With that out of the way I’ve managed to customise Kelvin’s script, so that it produces PDFs named following ISO19650-2 schema using text objects on each page’s titleblock. It requires text objects to be put on that particular layer ("titleblock index-AR002") and be named (Project Number, Originator, Zone, Level, Drawing Type, Role, Drawing Number, Drawing Title 1, Drawing Title 2, Drawing Title 3).
import Rhino
import os
titleblock = dict()
def createSinglePDF(view, titleblock):
dpi = 300
# settings.DefaultPrintWidthMillimeters = 0.18
filename = folder + "\\" + titleblock.get("project_number","0000") + "-" + \
titleblock.get("originator", "00") + "-" + \
titleblock.get("zone", "00") + "-" + \
titleblock.get("level", "00") + "-" + \
titleblock.get("drawing_type", "00") + "-" + \
titleblock.get("role", "0") + "-" + \
titleblock.get("drawing_number", "00000") + "_" + \
titleblock.get("latest_revision", "00") + " " + \
titleblock.get("drawing_title_1", "000000000") + " " + \
titleblock.get("drawing_title_2", "") + " " + \
titleblock.get("drawing_title_3", "") + ".pdf"
pdf.Write(filename)
for view in sc.doc.Views.GetPageViews():
for object in sc.doc.Objects.FindByLayer("titleblock index-AR002"):
if type(object) == Rhino.DocObjects.TextObject and \
view.ActiveViewportID == object.Attributes.ViewportId:
if object.Name == "Project Number":
titleblock["project_number"] = object.DisplayText
if object.Name == "Originator":
titleblock["originator"] = object.DisplayText
if object.Name == "Zone":
titleblock["zone"] = object.DisplayText
if object.Name == "Level":
titleblock["level"] = object.DisplayText
if object.Name == "Drawing Type":
titleblock["drawing_type"] = object.DisplayText
if object.Name == "Role":
titleblock["role"] = object.DisplayText
if object.Name == "Drawing Number":
titleblock["drawing_number"] = object.DisplayText
if object.Name == "Latest Revision":
titleblock["latest_revision"] = object.DisplayText
if object.Name == "Drawing Title 1":
titleblock["drawing_title_1"] = object.DisplayText
if object.Name == "Drawing Title 2":
titleblock["drawing_title_2"] = object.DisplayText
if object.Name == "Drawing Title 3":
titleblock["drawing_title_3"] = object.DisplayText
