Hi all,
I’m trying to get the obj file from a RhinoDoc to put in string without make a file, I try to see the FileObj.Write sourecode without luck also I try to make a ram file without luck. Anyone know how can I do this?
Thanks for the request, I need to work with the obj file in code and if I put it in the filesystem there can be copy/pasted to somewhere, I don’t care about .MTL because I only need .OBJ file.
For the moment I solved this here: Get an obj object from mesh
