I have a mesh and I’d like to convert it to obj in a string all is fine but I need help to make ‘f’ lines in obj for the moment I have this:
> public static String ExtractRenderMesh(Rhino.RhinoDoc doc)
> String s = "";
> Rhino.DocObjects.ObjRef objRef = null;
> Rhino.Commands.Result rc = Rhino.Input.RhinoGet.GetOneObject("Select surface or polysurface", false, Rhino.DocObjects.ObjectType.Brep, out objRef);
> if (rc != Rhino.Commands.Result.Success) return s;
> Rhino.DocObjects.RhinoObject obj = objRef.Object();
> if (null == obj) return s;
> System.Collections.Generic.List<Rhino.DocObjects.RhinoObject> objList = new System.Collections.Generic.List<Rhino.DocObjects.RhinoObject>(1);
> objList.Add(obj);
> Rhino.DocObjects.ObjRef[] meshObjRefs = Rhino.DocObjects.RhinoObject.GetRenderMeshes(objList, true, false);
> if (null != meshObjRefs)
> for (int i = 0; i < meshObjRefs.Length; i++)
> Rhino.DocObjects.ObjRef meshObjRef = meshObjRefs[i];
> if (null != meshObjRef)
> Rhino.Geometry.Mesh mesh = meshObjRef.Mesh();
> s += System.Environment.NewLine + " " + i + " " + System.Environment.NewLine;
> foreach (Rhino.Geometry.Point3f point in mesh.Vertices)
> s += "v " + point.X + " " + point.Y + " " + point.Z +System.Environment.NewLine;
> foreach (Rhino.Geometry.Point2f point in mesh.TextureCoordinates)
> s += "vt " + point.X + " " + point.Y + " " + System.Environment.NewLine;
> foreach (Rhino.Geometry.Vector3f point in mesh.Normals)
> s += "vn " + point.X + " " + point.Y + " " + point.Z + System.Environment.NewLine;
> if (null != mesh)
> doc.Objects.AddMesh(mesh);
> doc.Views.Redraw();
> return s;
I solved this inthis way:
> meshObjRefs = Rhino.DocObjects.RhinoObject.GetRenderMeshes(doc.Objects.GetObjectList(object_enumerator_settings), true, false);
> Mesh mesh = meshObjRefs[i].Mesh();
> s.Append("v ");
> s.Append(point.X.ToString(_allFloatDigits));
> s.Append(" ");
> s.Append(point.Y.ToString(_allFloatDigits));
> s.Append(" ");
> s.Append(point.Z.ToString(_allFloatDigits));
> s.Append(System.Environment.NewLine);
> vertex = mesh.Vertices.Count;
> s.Append("vt ");
> s.Append(" ");
> s.Append("vn ");
> s.Append(" ");
> s.Append(" ");
> foreach (Rhino.Geometry.MeshFace face in mesh.Faces)
> A = face.A + shift;
> B = face.B + shift;
> C = face.C + shift;
> s.Append("f ");
> s.Append(A);
> s.Append("/");
> s.Append(A);
> s.Append("/");
> s.Append(A);
> s.Append(" ");
> s.Append(B);
> s.Append("/");
> s.Append(B);
> s.Append("/");
> s.Append(B);
> s.Append(" ");
> s.Append(C);
> s.Append("/");
> s.Append(C);
> s.Append("/");
> s.Append(C);
> if (face.IsQuad)
> D = face.D + shift;
> s.Append(" ");
> s.Append(D);
> s.Append("/");
> s.Append(D);
> s.Append("/");
> s.Append(D);
> foreach (Rhino.Geometry.Vector3f point in mesh.FaceNormals)
> s.Append("#fn ");
> s.Append(" ");
> s.Append(" ");
> foreach (Rhino.Geometry.Point3d point in mesh.TopologyVertices)
> s.Append("#tv ");
> s.Append(" ");
> s.Append(" ");
> shift += vertex;
