Challenge:
Get ‘n’ number of colors which are consecutive in the rainbow.
Note: the input nr ‘n’ has to be able to change, so its alo possible its 8, or 25…
2023-12-26 Generate cesecutive rainbow colors.gh (16.3 KB)
Any suggestions?
Challenge:
Any suggestions?
I would think the easiest way to use the Gradient component. Something like this should work.
Gradient Lines.gh (8.9 KB)
This is easier. I use these ColorJa and ColorBa clusters all the time. They are not password-protected so can be edited to see how they work.
Gradient Line_2023Dec26a.gh (13.0 KB)
Internals of the ColorJ cluster:
Thank you both!
It worked to get the ‘rainbow’ colors.
Howeveer when having another critical look at it I found out I would like to get a more ‘result’ based color range something like:
green → Yellow → light blue → dark blue → yellow → orange → red.
Any suggestions?
Many thanks ![]()
You can right-click on the Gradient component and select a gradient preset… Or you can edit the colors/positions yourself directly by double clicking on the Gradient component.
The trouble with a list of colors is that when geometry changes, the color list must also be changed.
