I have Brep “1” and with BrepLoops.To3dCurves i get “2” but i like to get “3”.
The curve i have removed in “3” are 2 Curves overlapping complet but are part of the same curve as “2”.
can you post the geometry so it can be verified if this is a seam at point 2 ?
Do you want to write a getter to prompt for only the selection of what is visible in point 3 or do you wand to input the geometry and output just what is visible in point 3 ?
I building a complex script at this is just a small part of it. I only need to store the curve from “3” into an variable to use it later in the script. I allready use a GetObject to pick the geometry and only need a function with brep,brepface or surface input and curve return.
I would need it as generic as possible because the geometrys could change a little bit.
I have attached the geometry: example.3dm (36.6 KB)
Hi @Felix1, see if this is what you want, it seems to work on your example:
import Rhino
import scriptcontext
import math
def ExtractSharpEdgeCurves():
brep_id = rs.GetObject("Select Brep", 16, True, False)
if not brep_id: return
brep = rs.coercebrep(brep_id, True)
angle = math.radians(1.0)
curves = []
for edge in brep.Edges:
if not edge.IsSmoothManifoldEdge(angle):
curve = edge.DuplicateCurve()
curves.append(curve)
if not curves: return
for crv in curves:
crv_id = scriptcontext.doc.Objects.AddCurve(crv)
rs.SelectObject(crv_id)
