I tried to use the Brep.DuplicateEdgeCurves Method (Boolean) from Rhino Common but I realized it works for Surfaces only but not for polysurfaces however in Rhino Python the DuplicateEdgeCurves works for polysurfaces as well. Why is the difference?
https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_Brep_DuplicateEdgeCurves_1.htm
import Rhino
import scriptcontext
def DupBorder():
filter = Rhino.DocObjects.ObjectType.Surface | Rhino.DocObjects.ObjectType.PolysrfFilter
rc, objref = Rhino.Input.RhinoGet.GetOneObject("Select surface or polysurface", False, filter)
if rc != Rhino.Commands.Result.Success: return rc
rhobj = objref.Object()
brep = objref.Brep()
if not rhobj or not brep: return Rhino.Commands.Result.Failure
rhobj.Select(False)
curves = brep.DuplicateEdgeCurves(True)
tol = scriptcontext.doc.ModelAbsoluteTolerance * 2.1
curves = Rhino.Geometry.Curve.JoinCurves(curves, tol)
for curve in curves:
id = scriptcontext.doc.Objects.AddCurve(curve)
scriptcontext.doc.Objects.Select(id)
scriptcontext.doc.Views.Redraw()
return Rhino.Commands.Result.Success
if __name__=="__main__":
DupBorder()
