Geodesic Fractal
Here some experiments Geodesic used with some classical fractal trees.
The initial idea came from @masaaki.miki,
http://mikity.wikidot.com
https://www.researchgate.net/figure/3d-printed-geodesic-fractals-that-correspond-figure-1-top_fig2_281246096
and it is a sort of continuation from this discussion
I like a lot these simple complexity, here on a Chapiteau with paper material
love it @laurent_delrieu !!
Thanks,
I like it also a lot, but I’ll have to find a way to use it as a pattern for making a bowl or something like that. Something that could be laser cutted, then stamped.
@laurent_delrieu, you mean something you can laser cut on a 2D sheet that could further be fold onto a curved surface ? Is that even possible (or not to complex to acheive)…? Or will you make pieces that could be further assembled like you did in your small table exemple ?
-CC
I more think of things like that done by Nervous
https://n-e-r-v-o-u-s.com/shop/line.php?code=20
You made them flat then stamp
Something like that
Reminds me of the Alessi Mediterraneo fruit bowls. :slight_smile:
chapeau bas (or jaw dropped!)
No I don’t want to share.
