Geodesic Curves on Polysurfaces (not ShortPath)
Hello I’m trying to create a geodesic curve on a polysurface. ShortPath does this on one surface. I have a very complicated Polysurface.
Hello- I do not know of a way to get there in plain Rhino - it may be that a fancy Gtrasshopper plug-in can do this.
this will probably be iterative solution thus not exact. analytcal solution might exist only for a single surface. algorithm would need to alter positions on each subsurface edge and minimize the sum distance.
https://www.food4rhino.com/en/app/lion-fish
create it on a mesh, fine-tune stepwise on the polysrf ?
Hey Tom, Pascal, and Juan, I found this which is useful. It’s Kangaroo so already in Rhino 7. I will check out Lion Fish. I have to make a ton of these geodesic curves. So a simple solution not as complicated as this relaxed line approach would be best. Geodesic lines on a Mesh - #9 by davidsmavrov
Here’s a little cluster - it’s still relaxing lines on the surface like the above but perhaps easier to use.
geodesic_brep.gh (121.7 KB)
