Hello.
Can points be generated with a grasshopper function and have them have the ability to move with the mouse in the rhino workspace without doing a bake? That is, do an operation contrary to get points.
Yes, create the point in Rhino. Then, right click on the point param in Grasshopper then use SElect one Point, select that point. Now that point can be moved around and grasshopper will update.
Thanks, but I already know that procedure, I was referring to creating a point in the grasshopper worskapce without previously creating it in rhino, and then that point can be moved with the mouse in the rhino environment
GumballGH.gha (53.5 KB)
This is what you are looking for, I guess.
Do the same @scottd suggests, but without creating the point in Rhino first, just grab a point component in GH, set a point (which you specify in the Rhino environment anyway), which will be internalized automatically and therefore movable in Rhino (if itâs highlighted/selected in the GH canvas) without it being âphysicallyâ present in the viewport.
thanks
ok, thanks Iâll try it
