sample.gh (8.9 KB)
I am trying to generate .3dm file just by launching .gh
The attached .gh file contains the Launchbox’s ObjectSave component.
- After opening attached file, right-click the [path] component connected to [Dir] of the rightmost component.
- Then click “Select a directory”. Then select your desktop, for example.
- Overwrite the .gh file and close Rhinoceros and grasshopper once.
- This will probably generate a .3d file on your desktop (or may not…)
If a .3dm file is generated, delete it. - Reopen the .gh file you just overwrote
- Then, just opening the .gh file will not generate a .3dm file on your desktop.
In the current state, the .3dm file will not be generated unless I toggle the toggle button.
I want to generate .3dm file just by launching .gh
Because I want to start .gh with a batch file and save the automatically generated .3dm file in another folder.
Does anyone have an idea? Thanks in advance.
