Help on generating 3dm file using hops -- rhino.compute
line3.gh (11.4 KB)
So I have this simple gh script that makes some geometry and using TTToolbox
saves to a file in the temp folder, returns the filename as a result.
The real goal here is to use this template in a rhino.compute application to generate rhino 3dm files
Testing the definition using a c# app and rhino.compute gives a error and even a simple test using hops inside grasshopper does not work.
Can somebody tell me the reason and how to fix ?
tnks
Gerry
