I want to make a gene pool with just unique values. Is that possible and how do I do that?
I want to use it to as the genome for octopus, but I need the values to be unique.
Thanks in advance!
Best,
Bart
Thanks in advance!
Best,
Bart
Depends on whether you have more distinct values than genes. If yes, then it is at least theoretically possible.
What needs to happen when two values are the same? Should one of them be slightly moved? Both?
It’s easy enough generating -say- N different values, but I suspect the fact that you’re using a Gene pool means you have limited freedom as to the indexing of the values.
Typical ways to generate different values are:
Hello!
Would you have a good solution for implementing the slightly moved values?
For example lets say I have 5 sliders with values from 0…9. If any of the slider values are equal one of them should be increased or decreased by one.
The problem I run into is that after changing one value, it could become equal to another value instead.
