Hi!
I am working on my master thesis project with Wallcei X. I use gene pool to select points from grid surface. But it sometimes select the same points. Is there any way to prevent selecting same points from gene pool?
Thanks a lot…
Yes, if you use a gene pool as a selection mechanism for another list, you may end up with repetitive indices - What I personally do is to create a list of all possible indices and shuffle through that list with a gene- It is only one line of code in c# - I have attached a GH file for you and also a couple of screenshots for your reference. It can be done through Python as well but of course with different syntax.
Hi Milad. Isn’t using random values to shuffle the parameters of optimization, bad for it? Also isn’t that limiting the exploration of the parameter space?
Yes, I advise not to use the random seed in the optimisation problem - I don’t know the details of @y.gokce.s problem. But it appears that this is only selecting from a small set of indices. Anyways this is something that needs to be carefully thought about, in setting up a design problem. Another way of doing it could be as follows: using a gene pool to create a True Flase pattern for culling from a set of indices.
