Hi, welcome to McNeel Discourse.
Did you use a polysurface as a module? How is the module aligning with your grid?
If you can share a sample as a 3dm file, then it will be easier to see what is happening.
forum.3dm (4.9 MB)
I’m still new, I guess they are not polysurfaces anymore after meshing?
No. If you select the geometry, it tells you the type in the command-line. Also you can use “What” command to see the details.
Many times the mesh module works better than a surface, so nothing wrong with that. The problem is usually in the alignment from one cell unit to the next. I’ll look into your model and get back to you.
the problem is even if I do a stand up flat triangle I seem to be still getting all those unnecessary lines and points (“T” type joints)
There must be some deformation happening. Are you changing the scale?
I fixed it by using join, very strange
thanks for the help though!
