Hello!
I am trying to make an optimization of a part of a project based on the incidence of the wind and the area it occupies. For this I am using Butterfly and Galapagos.
To Galapagos, I am introducing sliders that control the position of some points that make up a curve and then extrude it with other values also controlled by Galapagos (at this point I am not sure that I am using many genomes).
For fitness I introduce the values of the area of the quadrilaterals (A, B, C, D in the attached drawing) that make up the initial polygon and a sum of the length of the vectors resulting from the Butterfly wind analysis.
The problems I think may arise when starting the Galapagos solver is that by entering as a constant all the values that do not form a surface from a polyline, make the fitness landscape level (beginner interpretation) and give up.
On the other hand, I do not know to what extent, this problem can be solved taking into account the duration of the creation of the snappymesh (especially) despite the fact that I do not care that the wind analysis is extremely accurate.
I also attach a photo of the configuration that I am using in galapagos.
¡Thanks a lot for the help!
