G2 continuity
Hi rhino community, i have a question for you.
Why are there 2 numbers when verifying curvature continuity of 2 surfaces? what do they correspond to?
Thank you !
Hi Enzo - from Help:
Curvature
Evaluates curvature deviation between the selected edge pair.
This option displays absolute and relative (in parentheses) deviations.
  • Absolute curvature deviation = (1/Radius1)-(1/Radius2)
  • Relative curvature deviation = (Radius1-Radius2)/(Radius1+Radius2)
Thank you Pascal !
And what number should i aim to have nice continuous reflexions ? Absolute : 0 and relative :1 ?
If Radius 1 equals Radius 2 then the relative curvature difference = 0 and absolute curvature difference = 0.
However if Radius1 is infinite (Curvature1 = 0, ie “flat”) and Radius2 is infinite (Curvature2 = 0, ie “flat” then relative curvature difference is undefined. However Rhino returns a value of 1 even though the curvatures match.
What is needed to be satisfactory for the intended application. Exact matching will look good, but in many instances less than exact will be satisfactory.
