Funny thing when switching from Raytraced to another display mode
Rhino V6 right up to this week’s RC:
Has anyone else noticed this? When a view is switched to raytraced the first time by using the dropdown menu in the viewport title and then, before retraced is complete, you pull the menu down again to switch to a different display mode and start down the list by mouseover Rhino will pick whatever item the mouse is on when a certain time elapses without a mouse button click.
As far as I can tell, if the retrace completes or on subsequent raytrace use in the same viewport the menu behavior is normal and you can mouse up and down all you want until you click on a display mode.
It is a known issue, and no fix has been found despite several vigorous attempts.
:frowning_face:
