I made a macro and Icon for “_MergeAllCoplanarFaces”. I use this command a lot and have the Icon/macro on two toolbars. However, recently, one has stopped working and I get the result “Unknown command”. But the other one in the other toolbar works?
I deleted from the toolbar the Icon that was not working, then shift-copied the working icon/macro to replace it. It worked once, then stopped again. Here is a print of the command history showing the same procedure just using the different icons. How can _MergeAllCoplanarFaces be an unknown command only in some instances?
3 extrusions added to selection.
Command: BU
Command: _BooleanUnion
Boolean union in progress… Press Esc to cancel
Creating meshes… Press Esc to cancel
Command: _MergeAllCoplanarFaces
Command:
Command: BU
Command: _MergeAllCoplanerFaces
Unknown command: _MergeAllCoplanerFaces
My Icon in my main toolbar.
