1.-Change direction with spacebar to visualarq styles like doors, walls intersection, walls similar to revit
2.-Have an independent panel of visualarq for the styles and not have to click inside the properties panel, the independent panel of visualarq would make it possible to enter directly to quickly edit a style
3.-Assign a material that has a hatch, for example if I put a pbr material on the floor I can assign a hatch that when I do the plan view it detects that material with its hatch and projects it on the floor plan
4.-Autodimensions for the entire floor plan (windows, walls, etc)
5.-Level of detail in the visualization of a cut, for example in the general cut that a simple hatch of a single type can be seen without differentiating the different layers that can exist in a slab, but in a section detail each layer can be distinguished with their respective hatch and legend
6.-All the 2d generated have their own viewport, model and layout section where you can place all the floor plans, sections, etc on a big canvas to have a quick review reading with pan mode, this would make the 3d not on the same model view that makes it heavier when working on 2d plans since it is all in one place and having it separated it looks better and more orderly
7.- Create tables for custom text filling by choosing the number of columns and rows. These tables could be used to place text of municipal codes, etc.
