Hello every one, I attempt to using the following function to extrude a mesh.
Public Function WithDisplacement (displacement As MeshDisplacementInfo) As Mesh
Dim k As Rhino.Geometry.MeshDisplacementInfo
k.ChannelNumber = 1
k.BlackMove() = 3
Dim sdd As Mesh
sdd = msh(0).WithDisplacement(k)
RhinoDoc.ActiveDoc.Objects.AddMesh(sdd)
RhinoDoc.ActiveDoc.Views.Redraw()
But the result show me that k is nothing? How to solve this problem?
Thanks. But I still have a problem. I modify my code:
Dim s1 As Rhino.Render.RenderTexture
Dim s2 As Rhino.Render.TextureMapping
Dim k As New Rhino.Geometry.MeshDisplacementInfo(s1, s2)
k.ChannelNumber = 1
k.BlackMove = 3
Dim sdd As Mesh
and the msh(0) already be added texture(see the figure). but I do not
know how to give s1 s2 value, how to do? many thanks.
I think that the problem has be solved through modifying the code:
Dim objj As Rhino.DocObjects.RhinoObject
objj = meshObjRefs(0).Object
Dim sindex As Integer
sindex = objj.Attributes.MaterialIndex
Dim matt As Rhino.DocObjects.Material
matt = RhinoDoc.ActiveDoc.Materials(sindex)
s1 = matt.RenderMaterial.GetTextureFromUsage(Rhino.Render.RenderMaterial.StandardChildSlots.Diffuse)
Dim k11() As Integer
k11 = objj.GetTextureChannels()
s2 = objj.GetTextureMapping(k11(0))
k.BlackMove = 0.5
k.FaceLimit = 10000000
Dim sdd As Mesh
msh = kpk.Item(0).Geometry
sdd = msh.WithDisplacement(k)
but when I execute the withDisplacement(k) function.....appear the warning
message" -- mesh memory limit hit "? could anyone help me?
