Fully joined wallls is possible?
Hello everyone, is there a way to fully join walls together so the walls could look like the one bellow instead of the above in the image? If its not, please consider implementing this, is good for diagrams and schematics
Hi @Leo13 There is no command to join walls so two walls becomes one. In the case of the aligned walls, you can delete one and stretch the other instead.
In any case, are the walls on top of the picture the same style? If they are, the intersection should hide if you uncheck the option to show the “Tangent Edges” in your current viewport Display settings.
