From stress to point data
Hi, my question is kinda hard but i would like to try anyway.
Basically I would like to know if it’s possible from a mesh to extract the correct quantities of the stress in each mesh subdivision
I my head every surface of the mesh has a center, using the command “area” it’s possible to get the centroid, would be great if that point could be associate with the corresponding stress level.
so basically, if there is a way from karamba to export the stress level from each mesh subdivision with the corrisponsing value from the center.
I have also uploaded a picture so it’s much more easy to visualize it.
hi @Samuele_Agrimi,
You can use “find similar member” for this.
color values mesh.gh (28.7 KB)
OMG, I have litteraly no idead how you discovered that, but thanks so much for your help and time
