Hi guys! I have been days searching for a method to do this in GH and Rhino 8
I don’t know if someone have done anything like this and can help me. I don’t have any usefull gh file or anything because i didn’t achieve any good result…
Thanks in advance!
Here is the .shp with the lidar points and the .shp with the building footprints Unique Download Link | WeTransfer
Here the link with the .shp of the lidar and the building footprints Rhino - Google Drive
What do you mean by “this”? You just showed us an image from a research paper by the looks of it. So you found that, but it still doesn’t have a name?
You mean to create geometry from a point cloud?
Even if you don’t have a file, at least explain what exactly you would want to achieve. Properly formulating the problem is half the solution
I’m sorry, I’m new with using the community…
basically I am searching the way of creating the geometry of complex roof by using the LIDAR data, yes. The image is not from an article, is just something i searched for clarify what I want to achieve
This sort of thing has come up before. I remember it from posts about the Gismo plugin that can process map data…
Gismo Roofs
This is not quite what you are after but might be a good lead.
Gismo Roofs from LIDAR and OSM
This is exactly on topic I believe but not sure it provides the solution you are after.
There’s a link to OSM info though. Perhaps going down that rabbit hole might get you somewhere!
Maybe @djordje has some more info on this?
