Frames to curves in grasshopper?
I have a series of simple frames (for a boat hull) and would like to run curves through the points to create the sheer/chine/keel lines. Basically a curve thru the first point of each frame (curve), then a curve thru the 2nd(mid) point, and finally thru the 3rd(top) points.
I found the DISC component that nicely finds the 3 points for each curve. Now I am stuck on how to find the 1st point for each curve from the output of DISC … to feed into the vertices input of the INTCRV component. Then same with the 2nd and 3rd points.
Of course there is likely a simple way to do this and my DISC approach is off base !
Is this what you’re trying to do?
connect_frame_points.gh (9.3 KB)
By chance, I just learned about “flip matrix” in another thread just a few moments ago. It makes this much simpler.
connect_frame_points_better.gh (4.2 KB)
The other thread:
exactly what I want … will give this a go … thanks webdunce !
