I try to make a curve through a set of points. Unfortunately, I get vertical lines instead of 1 curve. Anyone any idea how I can make it 1 curve?
difficult to say without a Grasshopper file
In the future you can paste the files directly here no need to wetransfer
I’m scared.
You need to sort the points and that works best when all section curves are in the same direction
Check the file
interpolate_ME2222_Re.gh (31.8 KB)
I flipped some of the curves so all curve planes Z vectors point in the same direction.
Then took all start points and made a curve, same for end points. Connected both and then sorted all points along that curve. Can be streamlined of course but that’s a start
Thanks!
