I often forget to connect to the VPN that I need to use to retrieve my Zoo license. When do, I need to reconnect and close Revit to open Rhino.Inside. I don’t know if there’s a limitation to what Revit allows you guys to do, but I wouldn’t mind having a means to reconnect to the zoo and then press a button to re-initiate Rhino.Inside within Revit. Perhaps that could be part of this pop-up as option 4:
4. Retry launching Rhyni inside…
Reconnect to the Zoo manually before pressing the button (subtext).
