I don’t have the Noto Naskh Arabic font on my system. If you make a text item in Rhino 5 (not using Grasshopper at all), do the letters also appear as squares?
No, that will zoom to the extends of the Grasshopper geometry in the Rhino viewport, even if this geometry is set to not be visible. At least, that is the way it appears to be in GH1, not sure if @DavidRutten has plans for that in GH2.
ok even if the component result is set to not visible (preview disabled).
I just experimented by closing the grasshopper document and now No se puede aplicar el zoom a algunas vistas, no hay objetos visibles. printed as expected
thanks
With my question, I’m trying to find out if this is a Grasshopper thing or a Rhino thing. So, again, if you make text using one of these fonts in plain Rhino, do the letters also appear as squares?
In rhino 6 draws a standard font . Only chraracter map is displaying the fons (i can copy-paste individual char only) ,I just wanted to draw some exotic character , soap and so …
except font sizes (they are each the size it want in rhino v6) this works better than v5. for all fonts i tested rhino v6 gets the “fallback font” instead of squares
