i just noticed that Focal Blur does not work when you enable the Parallel projection is that true? if so why is it not possible? Also the option disappears and in viewport properties and when you switch back to Perspective only comes back after selecting and deselecting an object, tested in v7 and v8
ok guys, since nobody had a look i bump this topic, the issue seems valid for V7 and v8, i get focal blur to render in parallel when i start in perspective and switching over while rendering but i can not adjust it.
the focal blur tab just vanishes when i switch to parallel but only after i start manipulating the view.
here in perspective projection
and here when i switch to parallel projection
but when i touch the viewport the tab vanishes.
thanks @encephalon
RH-82715 Focal blur works in Parallel view but no controls are available
