Does R6 GH have this feature?
It would be handy to be able to select a wire connection on a component and pan the screen view to the component that wire is connected to. Same way as you can select from the list of connections when disconnecting inputs.
Can you do this?
mattgaydon
(Matt Gaydon)
February 6, 2019, 11:16am
2
Do you mean, like when you select a component and then hold down Ctrl and use the Left or Right arrow keys to see whats connected to this component.
Holding down Crtl and Shift and using the arrow keys will mean the previous component is not deselected.
Sort of but I want to pan the screen to the component at the other end of the wire.
That is what Ctrl + Left or Right arrow keys does. It pans to the connected components.
Boom! We’re flying! Thanks!
It would be nice if you could select a wire to fly along, but it’s still helpful!
