(no answer on my topic I guess the solution is or too obvious or has been treated many times already)
PLEASE DELETE THIS TOPIC - (I can’t find a delete button)
I’ve a closed curve (black layer) on a flat unrolled surface. I’d like to flow that curve along a bent surface of the same dimension. I use the command FlowAlongSrf but the curve shrink (see blue layer). I tried with ApplyCrv too and I’ve also a big distortion which does not match the dimension of the surface. What am I doing wrong? Thanks!
4forum.3dm (201.5 KB)
