Trying to Flow Srf Along CRV without deforming in the bend of the crv just like the pipe. Is there a way to do this?
Please help.
FLow Srf along Crv.3dm (257.2 KB)
FLow Srf along Crv.3dm (468.4 KB) 1 Rail Sweep sort of worked . —Mark
Hi Marcel - I am not sure what you are trygin to do but Flow should work OK if you start with a straight object and a line:
Hi Pascal
I had help from a previous request I made to the forum which was very helpful to do the attached .See image. I did it with a “pipe command” ,
Now i am trying to do the same but this time with a square profile/section.
Hello- A Sweep1 of a square on the end of the curve, or Flow of a box, as in my image, ought to do it.
