Hi, everybody, I’m new here, nice to meet you all.
I’m new to rhino, this amazing software. While trying to flow some objects along surface, I came across something really annoying. The objects are there, I can highlight them, but the surfaces disappear.
By clicking on object’s details, Rhino gives me this:
Object one - Original.
surface
Object name: (not named)
Layer name: Surfaces::Stone-seed::Bixbite
Render Material:
source = from layer
index = -1
Geometry:
Invalid surface.
closed surface.
NURBS Surface"U": degree =3 CV count = 13 (0 <= U <= 0.171536)
“V”: degree =3 CV count = 7 (0 <= V <= 0.470813)
Edge Tally:
2 singular edges
1 manifold edges
= 3 total edges
Edge Tolerances: all 0.00394295
Vertex Tolerances: all 0
Render mesh: 1 mesh 561 vertices 512 polygons
Created with fast meshing parameters.
Analysis mesh: none present.
Object 2 - The same object that had been flown along surface.
surface
Render Material:
source = from layer
index = -1
Geometry:
Invalid surface.
closed surface.
“V”: degree =3 CV count = 9 (0 <= V <= 0.470813)
Edge Tally:
2 singular edges
1 manifold edges
= 3 total edges
Edge Tolerances: all 0.00416474
Render mesh: 1 object custom mesh 2 vertices 0 polygons
Included in this post, a print of the situation. I hope I’m not showing something that had happened to you before, my sincere apologies if this is a repeated post, but if not, how may I solve this issue? Thanks to all of you and have a good day.
