Flow along sphere
Hello!
I am trying to create a square cut out texture on the top of a sphere, something like the image attached. I tried flow along curve but it distorts the pattern a lot and also the flow goes around the top of the sphere rather than flow right over it. IMG_2418
Thank you. this is a cylinder though not a sphere. What I am having a problem with is the sphere.
Hi! Are you looking for something like this?
Hi! Yes this is the result im getting, but what I am looking for is for the squares on the top of the sphere to look like the image I sent, rather than to revolve around the center of the sphere. Does that make sense? So something like the image I attached here but squares instead of hexagons.
Hm, something like that on the top?
something like this but all around the sphere
I would still go with Lunchbox panels and then extract items from the list to isolate the top triangles. Then I would try to fill the space somehow with squares instead of triangles. I’ll have to think about it a bit :slight_smile: I’ll try to get back to you!
okay, thanks! :slight_smile:
Hi, @sbdeir you can use quad sphere for this exercise.
quad sphere.gh (13.5 KB)
Very nice! I recreated it with a few less commands.
wero quad sphere.gh (11.5 KB)
:+1:
you just need to flatten
Amazing! I’ve never used grasshopper before though :confused:
