I am working on creating custom Flip Data Matrix Function, which will divide an input tree into subTree of similar path indices i.e; {0;} as one tree and {1;} as another and so on. I tested the Custom flip data function on one of the subTree and it works. But when I iterate the whole function over the subTrees it fails to generate the nulls. Here is the snippet from the GH-Canvas.
Here is the Code of the complete process of Split tree & Flip Data Matrix
using System;
using System.Collections;
using System.Collections.Generic;
using Rhino;
using Rhino.Geometry;
using Grasshopper;
using Grasshopper.Kernel;
using Grasshopper.Kernel.Data;
using Grasshopper.Kernel.Types;
/// <summary>
/// This class will be instantiated on demand by the Script component.
/// </summary>
public class Script_Instance : GH_ScriptInstance
#region Utility functions
/// <summary>Print a String to the [Out] Parameter of the Script component.</summary>
/// <param name="text">String to print.</param>
private void Print(string text) { /* Implementation hidden. */ }
/// <summary>Print a formatted String to the [Out] Parameter of the Script component.</summary>
/// <param name="format">String format.</param>
/// <param name="args">Formatting parameters.</param>
private void Print(string format, params object[] args) { /* Implementation hidden. */ }
/// <summary>Print useful information about an object instance to the [Out] Parameter of the Script component. </summary>
/// <param name="obj">Object instance to parse.</param>
private void Reflect(object obj) { /* Implementation hidden. */ }
/// <summary>Print the signatures of all the overloads of a specific method to the [Out] Parameter of the Script component. </summary>
private void Reflect(object obj, string method_name) { /* Implementation hidden. */ }
#endregion
#region Members
/// <summary>Gets the current Rhino document.</summary>
private readonly RhinoDoc RhinoDocument;
/// <summary>Gets the Grasshopper document that owns this script.</summary>
private readonly GH_Document GrasshopperDocument;
/// <summary>Gets the Grasshopper script component that owns this script.</summary>
private readonly IGH_Component Component;
/// <summary>
/// Gets the current iteration count. The first call to RunScript() is associated with Iteration==0.
/// Any subsequent call within the same solution will increment the Iteration count.
/// </summary>
private readonly int Iteration;
#endregion
/// <summary>
/// This procedure contains the user code. Input parameters are provided as regular arguments,
/// Output parameters as ref arguments. You don't have to assign output parameters,
/// they will have a default value.
/// </summary>
private void RunScript(DataTree<Point3d> pts, ref object A)
GH_Structure<GH_Point> sortedData = new GH_Structure<GH_Point>();
GH_Structure<GH_Point> outData = new GH_Structure<GH_Point>();
List<int> pathIndices = new List<int>();
DataTree<int> pathTree = new DataTree<int>();
GH_Structure<GH_Point> ghStructure = new GH_Structure<GH_Point>();
GH_Structure<GH_Point> ghStructureOut = new GH_Structure<GH_Point>();
DataTree<GH_Point> ptsShow = new DataTree<GH_Point>();
for(int i = 0; i < pts.BranchCount;i++)
var branch = pts.Branch(i);
var path = pts.Path(i);
for(int j = 0; j < branch.Count;j++)
GH_Point myPts = new GH_Point(branch[j]);
sortedData.Append(myPts, path);
for (int a = 0; a < pts.BranchCount;a++)
var branches = pts.Branches[a];
var paths = pts.Paths;
for (int b = 0; b < paths.Count; b++)
if(paths[b].Indices[0] == a)
pathIndices.Add(a);
var uniqueItems = new HashSet<int>(pathIndices);
DataTree<GH_Path> sortedPaths = new DataTree<GH_Path>();
for (int j = 0; j < uniqueItems.Count; j++)
var path = pts.Paths[i];
if(j == path.Indices[0])
sortedPaths.Add(path, new GH_Path(j));
for (int a = 0; a < sortedPaths.BranchCount;a++)
var branches = sortedPaths.Branch(a);
for (int b = 0; b < branches.Count; b++)
int i1 = 0, i2 = 0;
if (branches[b].Indices[0] == a)
sortedData.PathIndex(branches[b], ref i1, ref i2);
outData.AppendRange(sortedData.Branches[i1], branches[b]);
//Flip Data Matrix Function Runs here inside the Loop
int length = outData.Paths[0].Length;
int num1 = outData.PathCount - 1;
for (int index = 1; index <= num1; ++index)
if (outData.Paths[index].Length != length)
Component.AddRuntimeMessage(GH_RuntimeMessageLevel.Error, "All paths must have the same length");
return;
int index1 = -1;
if (outData.PathCount == 1)
index1 = length - 1;
else
int num2 = outData.PathCount - 1;
for (int index2 = 1; index2 <= num2; ++index2)
int num3 = length - 1;
for (int index3 = 0; index3 <= num3; ++index3)
if (outData.Paths[0][index3] != outData.Paths[index2][index3])
if (index1 < 0 || index1 == index3)
index1 = index3;
else
Component.AddRuntimeMessage(GH_RuntimeMessageLevel.Error, "All paths may only differ at a single Position");
return;
int index4 = 0;
do
List<GH_Point> ghGooList = new List<GH_Point>();
GH_Path path = new GH_Path(outData.Paths[0]);
path[index1] = index4;
bool flag = false;
for (int index2 = 0; index2 <= num2; ++index2)
if (index4 < outData.Branches[index2].Count)
ghGooList.Add(outData.Branches[index2][index4]);
flag = true;
else
ghGooList.Add(null);
if (flag)
ghStructure.AppendRange(ghGooList, path);
++index4;
else
break;
while (index4 <= int.MaxValue);
//Flip Data Matrix Function Ends Here
outData.Clear();
ghStructureOut.MergeStructure(ghStructure);
ghStructure.Clear();
for (int i = 0; i < ghStructureOut.PathCount;i++)
var branch = ghStructureOut.Branches[i];
var path = ghStructureOut.Paths[i];
ptsShow.AddRange(branch, path);
A = ptsShow;
// <Custom additional code>
// </Custom additional code>
Also Attached is the GH Script. Here : SubTree & FlipDataMatrix-V2.gh (18.6 KB)
Anyone can you help, what could be wrong?
