Flatten surfaces of a divided loft
I would like to flatten (7) surfaces of a divided loft. Would appreciate any assistance with continuation of grasshopper code below. Blue is desired output and red is what I have been able to accomplish so far.
check the loft options from normal to straight
good try, however, two curves are not straight lines and new (7)blue surfaces are not straight/planar as intended.
I couldn’t find the divide component you used. Are you a Rhino 5 user?
I created the surfaces in two ways resulting in different planar surfaces.
  1. dividing the curves
  2. dividing the loft
div_flat_srfs.gh (13.4 KB)
It is Divide Domain². Found in Maths > Domain.
Thank you!
I thought that the S output stands for surfaces not segments :sweat_smile: (No icon in the printscreen)
Added a third option: div_flat_srfsV2.gh (15.7 KB)
ME_Mark, your .gh works! Thank You!
