Hi everyone,
I was checking this link http://www.grasshopper3d.com/forum/topics/curve-degree
and I tried to do the same
using Rhino.Geometry.Curve;
//Curve degree
if(x != null)
A = degreeCurve;
but I got this message
Error (CS1003): Syntax error, ‘(’ expected (line 70)
Error (CS1026): ) expected (line 70)
Can someone tell me what I´m doing wrong !!!
Thank you in advance
dale
(Dale Fugier)
4
Try this from a command:
ObjRef obj_ref;
var rc = Rhino.Input.RhinoGet.GetOneObject("Select curve", false, ObjectType.Curve, out obj_ref);
if (rc == Result.Success)
var curve = obj_ref.Curve();
if (null != curve)
RhinoApp.WriteLine("Curve degree = {0}", curve.Degree);
return rc;
– Dale
@dale
Sorry for being a noob in C#, but I don’t get the idea how or where I should put that script.
@Baris
Your pic have helped me to reach my goal, sorry if it got deleted, anyway I have flagged it asking the moderators to keep it.
@ All
By pure accident, this is what have functioned with my case.
A = x.Degree;
Now the important question, why the editor didn’t recognised “Crv” nor “Curve” ??? That have baffled me.
And thank you all
because you didnt make a curve named Crv or Curve. Your curve is most likely named x.
Actually, I have copied and pasted the example that I have mentioned in the quetion at the top of the thread
Yea, the curves name there is x.
