Finding and reusing geometry like a cluster
I know we can create and name clusters, and easily reuse them by typing its name and clicking on it. And if i have 10 examples of “Cluster A”, and change one without disentangling it, then all the 10 examples will change too - so theyre linked to eachother by this given name.
I was wondering if there is a way to do the same with geometry.
I often work with big scripts, counting 2000+ components, creating whole models in Revit. This model usually has 10-15 base geometry elements which are reused millions of times - this i usually do by scrolling to the spot theyre in and copying them, or placcing a new command and connecting the output of the base geometry to it.
And this does work, but it would make my job A LOT easier if i could attach a name to the geometry command and reuse it by looking for it in the component search bar, while it stays referenced to the first example and updated each time the 1st example gets updated. The exact way that it works for clusters.
I also do not want to put it inside a cluster, as often the base geometries are just extracted from Rhino/Revit so it’s just 1 command on the canvas thing.
Is there a plugin for that, or an option in the defaults?
Hi Hana,
There is work in GH2 in this regard (Shout / Listen Global variables), but that is not going to help in his case.
It sounds like you are working with geometry, what about using the GHDATA workflows? This could allow you to break up your large scripts as well.
Note that you can have multiple Data Output in a file and they handle branches.
That’s unfortunately not what i’m looking for, but thank You.
My base geometry is just curves, planes and points - and with intersections and mathematical commands i create a bridge model (together with Revit Adaptive families)
For example this is my start
and from there i extract everything else:
and rather than copy/pasting those ones or looking for them in the middle of a script, id prefer if i was able to just search and insert them (exact way as clusters)
i tried placing some of those base geometries into a cluster and then insterting it - but i just end up with the commands itself (crv/plane/point) without the reference to the original input
Is this tool a option for you ?
https://www.food4rhino.com/en/app/telepathy
Maybe another option is to use hops with local server ….just a guess.
yess! amazing, thank you! that’s exactly what i had in mind!
