Hi! How to find points on interstion surface?
Surface Closest Point then filter by ‘Distance’ = 0.
3. Attach minimal versions of all the relevant files
Thank you for your explain!
You might need to use Similar instead of Equals.
thank you for your answer but I have one more problem.
on sketch, I hope to except points on curve.
I need points on surface.
Apparently you don’t understand how important it is to post your file.
help! ! This project need on punching panel.
I will make a hole two different surface and different hole size on divide surface.
please click this link:
and then use google translate to understand.
Ben
thank you for tell me.
I will follow menu.
